Activity Forums Avid Media Composer AVID Codecs 2.3.9 for Windows has no Alpha?
  • AVID Codecs 2.3.9 for Windows has no Alpha?
    Posted by Chad Gilmour on February 10, 2014 at 11:25 pm
    I’m running Windows 7 with AVID’s codecs, version 2.3.9, and no matter what combination of settings I set in After Effects, I can’t get a quicktime file with an alpha channel. I’ve made sure to set RGB+Alpha as well as selecting either “compressed” or “uncompressed” in the Avid codec dialogue box. However every time I export a file using an Avid codec, no alpha channel comes through. I can get an alpha channel with any other codec ie: jpg2000, animation, etc.
    Anyone else having this issue? Is there a bug in this version?
    Mark Renz replied 12 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Ricky Barrow
    February 11, 2014 at 1:51 pm
    I don’t believe Avid Codecs support alpha.
    Ricky
  • John Pale
    February 11, 2014 at 2:42 pm
    The do support alpha.
    Make sure you have millions + and not millions of colors selected.
  • Chad Gilmour
    February 11, 2014 at 3:04 pm
    Thanks for the prompt reply’s! Just to make sure I’m not going insane, I took screen grabs of what I’m doing with the result. They show me creating a simple comp, setting to Millions+, and adding the alpha in the Avid codec box. After rendering, the file has no alpha channel. The attached pics show exactly what I did. Am I missing something?
    Result:
  • Ricky Barrow
    February 11, 2014 at 3:16 pm
    I believe “Unmatted” is what you want but you might try matted – That was what stumped me when going to Avid…but I also used a different codec because I thought I read DNxHD did not support alpha from AE – glad to hear from John that they do – I will need to experiment now!
    Ricky
  • Mark Renz
    February 11, 2014 at 4:27 pm
    We use DNxHD codecs with all our work coming out of AE and it works with alpha. The 444 codecs are for RGB projects. Try a DNxHD resolution that is not 444, unless you are working in an RGB project.
    Mark Renz
    Senior Editor
    Outpost Worldwide
  • Chad Gilmour
    February 11, 2014 at 5:33 pm
    Great tip! It worked using DNxHD 220 8 bit with an uncompressed alpha channel. That will work for now, but I’m still curious about why I can’t get a 444 codec exported with an alpha? I really prefer to have everything coming out of AE as uncompressed as possible since it will ultimately get compressed at least 1 or 2 more times by final delivery.
    Thanks for the help!
  • Mark Renz
    February 11, 2014 at 5:38 pm
    There is a 10 bit version of 220 to use.
    Mark Renz
    Senior Editor
    Outpost Worldwide
