Avid codec with After Effects
Hello,
I have been asked to deliver files wrapped with the Avid codec and in 1080p. I am creating timelapse clips in After Effects and rendering out.
My normal workflow is to use the Cineform codec and the files come out fine and in progressive.
The only thing I have changed in my workflow is to use the DNxHD codec and it is turning my files into interlaced. I have been using an Avid DNxHD codec when rendering quicktime files.
Can someone advise is there a way around this? Sorry if I have not enough info, let me know and ill give it.
Creating timelapse from image sequence, onto a comp, adjustments then add to render. I never have any upper or lower field, always left none.
