Activity Forums Adobe After Effects avid codec problem
  • avid codec problem
    Posted by Lori Newman on February 5, 2009 at 4:23 pm
    I’m working in CS4, rendering a file with an Avid Meridien Compressed codec with an alpha channel to an editor using Avid Express Pro. I select the Avid codec for output but the quick time comes out as animation. Any suggestions?
    thanks,
    Lori
    Lori Newman replied 17 years, 7 months ago 2 Members · 4 Replies
  • Lori Newman
    February 5, 2009 at 4:35 pm
  • Lori Newman
    February 5, 2009 at 4:36 pm
    Is there a way to remove my post from the list?
  • Kevin Camp
    February 5, 2009 at 6:04 pm
    [Lori Newman] “Is there a way to remove my post from the list?
    not that i know of. if you question was answered or you figured it out on your own, you can just reply that the problem was solved to end the thread… you might also add your solution, it may help someone else out later on.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Lori Newman
    February 5, 2009 at 6:07 pm
    I solved this problem by using the correct codec (the one I used was for a later system) and doublechecking that my output module was correct on each level.
    thanks!
