Activity › Forums › Adobe After Effects › Avid Codec for AE won’t export
  • Avid Codec for AE won’t export
    Posted by Alex Kogan on June 22, 2006 at 4:24 pm
    I’m trying to export for someone on an avid using the Avid compressed codec that I downloaded and placed in the quicktime folder in the library and it won’t export to a QT movie. I get an error -8963. HELP! PLEASE! Thanks!
    Alex Kogan replied 20 years, 3 months ago 3 Members · 3 Replies
  • Joseph W. bourke
    June 22, 2006 at 4:38 pm
    There’s a possibility that the error you’re getting is related to the pixel size of the comp you’re using (720×480, etc.). Some pixel aspects don’t work when you render (for example, if I have a 720×486 comp, and I try to output it to DV25, I get an error, because DV25 is 720×480). Ask your AVID editor what he/she needs first, then setup your output (and create a template for it, so you don’t forget next time).
    I’ve had very good luck sending stuff for our AVID Newscutter Adrenaline (it wants DV25 – 720×480, lower field first). I usually use the Quicktime Motion JPEG A that comes with After Effects – I don’t bother to use the AVID installable codec (although I have installed it) because the file size tends to be huge, and the render long. The Quicktime Motion JPEG A is a fast render, small file size, and it imports quickly into our AVID and looks very good. Good luck.
    Joe Bourke
    Art Director / WMUR-TV
  • Lars Bunch
    June 22, 2006 at 4:51 pm
    Joseph speaks truth. Your problem is almost certainly the pixel dimensions of your comp.
    I render Avid Meridian codec files for a client very frequently. These must be 720×486 – no exceptions – or else the render will fail. Usually when I have a failed render for this client, it’s because I have set up the comp improperly. Usually I will render both an uncompressed version and a compressed version. These import very quickly into the Avid whereas the editor has often complained of non-meridian codec files taking a long time to import.
    As mentioned above, this may not be right for all Avid codecs so check with your client.
    Hope this helps,
    Lars
  • Alex Kogan
    June 22, 2006 at 5:10 pm
    That was the problem. I saw on the Avid page that it needed to be 720×486, but somehow I thought it said 480. Thanks Guys.
