Activity Forums Avid Media Composer AVID changes system audio volume?
  • AVID changes system audio volume?
    Posted by Christopher Travis on July 6, 2012 at 8:59 am
    Hey,
    I’m playing some music in a web browser, and when I switch back to AVID, it brings the system volume way down so I can’t hear the music anymore.
    I notice there’s a system mute button above the timeline which mutes all outputs from the machine, I’m guessing I’ve also accidentally adjusted some “system volume” slider/setting somewhere else in the programme. Does anyone know what I’m talking about?
    Chris
    Blake Hodges replied 13 years ago 4 Members · 5 Replies
  • Michael Phillips
    July 6, 2012 at 11:55 am
    That same volume icon is also a slider for volume itself – behaves like the volume button of the OS for Mac or PC. Click and hold, then slide up and down for level.
    Michael
    Michael Phillips
  • Christopher Travis
    July 6, 2012 at 12:38 pm
    Hmmm, this doesn’t seem to work for me.
    do you mean this icon?
    Because that just seems to be a volume on/off toggle switch to me.
    I’m using Symphony 6 by the way, does this make a difference?
  • Michael Phillips
    July 6, 2012 at 3:55 pm
    If you click and hold the mouse down, it becomes a volume slider.
    Michael
    Michael Phillips
  • Jonathan Dean
    October 22, 2012 at 8:11 am
    My Avid has suddenly started to do the same thing.
    It won’t play audio from any other source other than Avid UNLESS I have the Avid windows on top of all the other programs (Mac).
    Note: It doesn’t just turn the volume low, the audio speaker monitor symbol turns to mute when I click anywhere else other than Avid.
    Michael, your click and hold suggestion doesn’t seem to do anything for me either. Christopher did you sort this at all?
  • Blake Hodges
    August 16, 2013 at 6:46 pm
    @Michael Phillips
    Had the same issue and your solution worked for me. Thanks so much!
    FYI to others: I click on the audio speaker icon in AVID (pictured in the thread) and holding down my click, a little vertical slider appears just to the right of the icon. It’s a little clunky cus I still have to hold the mouse click down as I move my hover over the slider, but once you do, you can slide the volume up and down.
