Activity Forums Avid Media Composer Avid – Can’t import video files
  • Avid – Can’t import video files
    Posted by Generosity on November 11, 2007 at 11:39 pm
    I recently installed Avid Free DV on my PC, and am having problems importing video into a project.
    I have tried several codecs using both AVI and MOV file types, I even tried encoding an MOV using the Avid Quicktime codec from Avid.com. Nothing has worked – audio usually imports properly, but the video takes usually takes an hour or so to process, then shows up as solid white or black in Avid.
    Am I missing something? Maybe wrong/missing codecs, or a hidden setting or something? Any help or suggestions would be most appreciated.
    Nate
    Generosity replied 18 years, 9 months ago 3 Members · 5 Replies
  • Accountfrozen_needs_realname
    November 12, 2007 at 5:05 pm
    You are likely missing whatever codec the original files were created with. The white or black screen with audio is often exactly that.
    You would need to find out what codec was used to create the files and install that codec on your machine.
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
  • Erik Pontius
    November 12, 2007 at 5:49 pm
    There is a nifty utility for the PC called “GSpot” that can help you to identify what codec a file was encoded with.
    https://www.headbands.com/gspot/
    Even when encoded in Avid’s quicktime codecs, it will still take Avid time to “import” the video since it is essentially converting or re-wrapping the quicktime MOV to Avid’s OMF file format to edit.
    Also remember that the Avid codecs usually have strict requirements in terms of frame size.
    Erik
  • Generosity
    November 12, 2007 at 7:00 pm
    Well, the thing is, all of my video files play fine on my machine. I tried importing several different file type which used several different codecs, and I have all the codecs those codecs installed on my machine. Also, even the file I encoded with the Quicktime Avid codec would not import the video into Avid at all.
    I’m beginning to think there’s either a problem with the program or the install, or something small and insignificant I’m missing…
    Thanks for the replies.
    Nate
    November 14, 2007 at 8:56 pm
    I have not worked with Avid FreeDV. It may be a limitation of the free software.
  • Generosity
    November 14, 2007 at 10:50 pm
    In case anybody’s interested or runs into the same problem, I think I’ve figured it out. I think you’re right, it’s a limitation of Avid Free DV. It is very limited in what it can import from an external file – only certain MOV files and DV streams. So I was finally able to get some video into the program by converting some video into a .dv DV Stream file, then importing that into Avid.
