Activity Forums Avid Media Composer Avid Bin File changes to Document file
  • Avid Bin File changes to Document file
    Posted by Nancy L. sutton smith on May 22, 2016 at 9:35 pm
    I moved a lost sequence out of Avid Attic into the Avid project, worked on it all morning, closed it without closing the project, and now it appears as a Document instead of an AVID Bin File as it was when I was working on it. And it no longer appears in my project. I have worked on this project on my Raid drive for over a year without this trouble. I just noticed that Avid said not to upgrade to El Capitan but I did. Could that be it?
    Nancy L. Sutton Smith
    Sutton Bay Media Company
    Nancy L. sutton smith replied 10 years, 3 months ago 2 Members · 3 Replies
  • Nancy L. sutton smith
    May 22, 2016 at 9:41 pm
    The sequence had simply lost its extension so I just added .avb and it is now working. Am I handling the sequence incorrectly when I copy it from the Attic to the project?
  • Michael Cummins
    May 22, 2016 at 9:48 pm
    Can’t say for Mac, but on Windows the bin files saved in the Attic typically have no extension. I always have to add the .avb to the filename once I copy it out of the Attic. Your OS could be trying to help you out by automatically assigning it a document extension.
    May 22, 2016 at 11:23 pm
    I bet that’s it, thank you! Because it started with .avb but then lost it. And I saw that happen with two others so I will always add it from now on. Appreciate it!
