Activity › Forums › Avid Media Composer › AVID Backup
AVID Backup
Posted by Peter Raymond on April 3, 2009 at 12:11 amWhat tools do you use to back up your Avid media?
I need to get media off of a LAN share for offline storage.
Smiling Editor replied 17 years ago 6 Members · 5 Replies -
Jason Hunter
April 3, 2009 at 12:47 pmI recommend using G-RAID firewire drives. Just duplicate your sequence into a new bin, right-click and select consolidate, select the FW drive, and when it’s done save a copy of your bin to that FW drive too.
AVID’s media tool is rock solid and I recommend it over any other 3rd party tool our there.
David Braswell
April 3, 2009 at 3:24 pmFor the actual backup media we’ve used Quantum LTO Drives for a year or two now. I’m always leary of storing media on drives that aren’t spinning and we don’t have that kind of space to archive the projects we do.
Kris Anderson
April 3, 2009 at 9:04 pmI find Avid’s media tool still misses some media and have always found it top be less than accurate. I use Media Mover to isolate the project’s media files and then back up to hard drive. I would like to go to DLT but the initial buy in cost ($6k aud) is prohibitive at the moment.
https://randomvideo.com/products/mediamover_avid.html
Job Ter burg
April 4, 2009 at 7:39 amCheck out Vice Versa Pro if you need to copy large amounts of files. I also use it to do incremental backups on current projects.
Smiling Editor
August 27, 2009 at 3:16 pmI love Media Mover – 3.1 is really fast for backing up projects from Avid on my Mac. I can’t seem to get an answer whether 3.1 will work on Leopard and Media Composer 3.5?
Nancy
