Activity Forums Avid Media Composer avid audio compressor
  • avid audio compressor
    Posted by Dst123 on May 12, 2006 at 2:56 pm
    Has anyone had any luck utilizing the audio compressor that comes with avid? I am trying to make my parameters to broadcast specs in regards to audio and I am not getting it? Any help would be appreciated, thanks in advance dt
    David Braswell replied 20 years, 4 months ago 3 Members · 2 Replies
  • Steve Pankow
    May 12, 2006 at 7:23 pm
    I’ll second that – I really hate the lack of documentation on the built-in audio plugs for Avid. They’re just *making* people go out and buy third party stuff to get things done.
  • David Braswell
    May 12, 2006 at 9:02 pm
    The preview feature is semi-useless, but I’ve had good results with the plugin itself. Assuming your audio levels were “good” to start with, try the default settings. I’ve noticed that you can generally be a bit more aggressive with good software compressors vs. hardware comps. I often wind up with settings similar to the following:
    between 3:1 and 4:1 compression ratio
    10-50 ms attack, kept short for transients and plosives
    -15 to -24 threshhold – again, quite a bit more agressive than a typical analog setting
    150-400 ms release – set longer than the attack to prevent breathing
    +1 to +3 gain to bring overall level up
    With these settings I’m typically peaking around -14 on my Adrenaline, and averaging between -7 and 0 on my Beta deck’s meters. These are just suggestions, of course, let your ear guide you 🙂 Perhaps one day Avid audio will be more like Premiere’s mixer. But the ‘Suite does work… just clunkily.
