Activity Forums Avid Media Composer Avid Attic location – can it be changed to another Drive?
  • Avid Attic location – can it be changed to another Drive?
    Posted by Alex Bond on July 31, 2009 at 10:22 am
    I’m running Avid Media Composer 2.6.6 with a tiny tiny C: drive. Media is stored on a 3 terrabit editshare.
    I’d like to change where Avid puts the Attic as I have another internal hard drive and the C: drive will run better if it’s not quite so full – Is it possible to change where Avid puts the Attic? I can’t see a setting for it.
    Please don’t suggest a new C: drive – I know it’s a solution but I can’t bear to reinstall everything when it’s working!
    Thanks in advance
    Alex
    Job Ter burg replied 17 years, 1 month ago 2 Members · 3 Replies
  • Job Ter burg
    July 31, 2009 at 12:56 pm
    You would not have to reinstall. You can use a disk cloning application like Norton Ghost or Casper, then replace the HD with the new (larger) clone.
  • Alex Bond
    July 31, 2009 at 12:59 pm
    That’s interesting, thanks
  • Job Ter burg
    July 31, 2009 at 11:24 pm
    Best thing about such applications is that you can put a clone of a perfectly working install of your C-drive on the shelf. If something goes wrong, you can simply put in the cloned drive of the functional system and continue working (OK, you need a backup of your project files from the C-drive, but you should have those anyway).
    Also, I use this method when I’m upgrading. I had 3.1.1 installed, had a clone of the system drive, then installed 3.5.4. If there’s an issue with 3.5.4, I’m back to 3.1.1 real fast.
