Activity › Forums › Avid Media Composer › AVID application
  • AVID application
    Posted by Ryan Gilding on January 27, 2010 at 4:47 pm
    I am running AVID Media Composer Nitris DX on Windows XP. When I try to open the application this message appears…”The application has failed to start because CoreUtils.dll was not found. Re-installing the application may fix the problem.”
    This all started after I updated my Sony XDCAM ex clip browser. Do I have to re-install the AVID software or is there something else I can do? It simply will not launch!
    Job Ter burg replied 16 years, 8 months ago 2 Members · 1 Reply
  • Job Ter burg
    January 27, 2010 at 11:06 pm
    If it tells you to reinstall, I’d give that a try. Takes less than 10 mins, usually.
