Activity Forums Avid Media Composer Avid and Edit* compatibility
  • Avid and Edit* compatibility
    Posted by Tony Brecknock on September 11, 2007 at 4:27 pm
    I have several logs that we have done on Edit* and with the new purchase I need to be able to import them into Avid – any suggestions?
    I also am planning on doing offlining on Edit in SD and importing edl into Avid for online. Unfort. I lose the source clip information when I do this. Any suggestions on the best way to do this?
    Phil Byrd replied 18 years, 11 months ago 2 Members · 1 Reply
  • Phil Byrd
    September 12, 2007 at 1:51 pm
    A year ago I made the jump to Avid from Edit*. And I really miss edit*.
    If you offline with Edit*, you should have no problem sending an EDL to Avid. I was always successful using Grass Valley format.
    For exporting logs, I’ve moved each bin to a timeline and exported an EDL. The Avid lets you organize the files in a bin. Not elegant. But it gets the job done.
