Activity › Forums › Adobe Premiere Pro › AVID Ale Import
  • Troy Murison
    April 20, 2006 at 1:29 am
    Not that I know of. If you have a Avid around, you could make bins
    then lay all the offline clips onto a timeline in ascending TC order
    then export a CMX EDL though. That would give you a list to conform
    in PPro. What was the ALE created from? If it’s really just a tab
    delimited (?) text file, PPro may be able to import it as a batch list.
    Look up batch list in PPro help. There are specific formatting
    requirements that I can’t remember for it to work right. Good luck!
    -Troy Murison
    Flyingspot
    Seattle
  • Rich Reynolds
    April 20, 2006 at 4:00 pm
    Troy,
    These were all created on a shoot in AVID media log. One problem with edl’s is no comments and truncating of source names.
    Any other ideas would be greatly appreciated.
    Rich
  • Troy Murison
    April 20, 2006 at 7:06 pm
    Yeah, that would be bad…
    It seems like there should be a way to get a tabbed list out of ALE
    and then import that into PPro, but I’m not in front of either system
    right now, so I don’t know if the list from ALE will be formatted
    right for PPro. I know each needs a certain order (ie: reel name,
    source in, source out, name, comment, etc.) but I can’t remember
    what that order is for either system or whether they’re ‘compatible’.
    I’ll try to look into this later today….
    -Troy.
  • Harm Millaard
    April 20, 2006 at 7:21 pm
    Best way to import ALE is to go to your local pub and order some..
    Harm Millaard
  • Rich Reynolds
    April 20, 2006 at 11:14 pm
    Thanks Troy!
  • Troy Murison
    May 5, 2006 at 7:26 pm
    Rich,
    Sorry for the delay- too busy and forgetful mind here….
    Your post on Adobe’s site reminded me. Here’s what I found
    today and posted on Adobe forums as well:
    I was able to import a short list from Avid Express Pro. Here’s
    what worked for me:
    In Avid, I exported my bin as Avid ALE
    Rename that file with a .txt extension instead of .ALE
    In PPro, go to Project/Import Batch List and select the .txt file
    That was it- in my case it worked. I didn’t expect it to work though
    because the ALE and PPro’s requirements for formatting are different.
    ALE goes like this:
    Clip name, Start time, end time, Tape name, drive
    PPro batch lists go like this:
    Tape name, Start time, End time, Clip name
    When I imported the ALE, the drive information from the ALE was placed
    in the Log Note column of the PPro project window.
    What I figured I would do if this did not work was to open the ALE
    file using Excel, re-arrange the columns to the PPro batch order, save
    it as a .txt file and then import that. I didn’t try that, and I’m
    out of time, but that could be an option as well.
    Good luck, I hope this helps!!!!
    -Troy Murison
    Flying Spot
    Seattle
