Activity Forums DaVinci Resolve Avid Aiff won’t import what am i doing wrong?
  • Avid Aiff won’t import what am i doing wrong?
    Posted by Mike Jeffs on September 19, 2011 at 5:39 pm
    Another post from me but i’m learning thank you all your help.
    I can’t seem to get a Avid Aiff to import into resolve.
    The work flow has gone like this. Files are ingest into the Avid Media Files -> 1 as XDcam 422 50mbs MXF files brought into a timeline edited. Then a Aiff was exported
    In Resolve i go into the conform page I click the load under the Timeline Management. in the dialog box i select the Aiff file. it loads the data and askes me where the files are located. I tell it to find the files in the Avid Media files. I then get a dialog box that say it found a bunch of info from the Aiff but 0 clips were loaded.
    am i doing something wrong?
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
    Clement Hobbs replied 15 years ago 4 Members · 4 Replies
  • Danny Scotting
    September 20, 2011 at 1:35 am
    Could be that the AIFF has not been exported correctly. The manual says –
    A single 16 or 24-bit/48KHz AIFF or WAV file on an accessible volume.
    If its not that format it won’t load.
    I also extract the audio to a separate folder and keep them all in the same place away from the media to keep it all clean.
    Danny Scotting – Senior Colourist
    Post Op Group Sydney
    https://postopgroup.com.au/site/?page_id=1052
  • Mike Jeffs
    September 20, 2011 at 1:49 pm
    I am such a idiot I typed Aiff But what i meant was AAF (to many acronmys) i was meaning video not audio
    Sorry
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • Sascha Haber
    September 20, 2011 at 2:11 pm
    Well, the first thing you should do is load all the media manually and not use those options, they wont work.
    Then I would actually export an EDL for the conform and see it that one does one track properly.
    if so, try the AAF again.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Clement Hobbs
    September 20, 2011 at 4:03 pm
    Resolve doesn’t read MXF wrapped XDCam files according to their supported Codecs list, only quicktime wrapped.
    Check here:
    https://www.blackmagic-design.com/media/1764192/DaVinci_Resolve_8.0_Supported_Codec_List.pdf
