Avid / AE roundtripping for stop-motion film retiming, with a twist
Hey guys,
I’m trying to do a pretty tricky deal with After Effects coming from Avid. Here’s the short of it:I want to take a sequence from Avid to AE using the pro import function (via an AAF file) so that I can get all the shots I need with handles in one fell swoop. It’s all stop-motion footage shot on film so I’m using AE mainly to re-time the puppets’ moves that are a little wonky. This means I need AE to work with image sequence versions of all the shots, which will allow me to easily remove and extend single frames.
Since pro import only seems to make QT reference files that link to the Avid footage, is there:
A) a quick way to take my multi-layered composition and simply convert/proxy all it’s footage to image sequences, or
B) a way to convert the whole original video file of the lab roll into an image sequence and proxy all the composition footage to that?
Oh, and here’s the kicker to all of this: There’s a very good chance that we’ll want to do a match-back to 35mm film for distribution (meaning we need an EDL from Avid). Is there a way to accomplish all of this and still retain the data needed for the EDL?
I had considered just sucking it up and cutting the frames in Avid, but I’d really, really like to avoid that headache. With the amount I’m doing I’d need to “make edit at cursor” for almost every frame of a 5-minute sequence.
