Activity Forums Avid Media Composer Avid Adrenalin HD export to AfterEffects
  • Avid Adrenalin HD export to AfterEffects
    Posted by Bonnfox on December 6, 2006 at 10:39 pm
    Hello,
    I was just wondering if somebody could point me in the right direction. I need to export HD video from my Avid Adernalin HD in its native resolution uncompressed for use in AfterEffects. Which codec? Any help is appreciated!
    Wes Plate replied 19 years, 9 months ago 3 Members · 4 Replies
  • Gooooo
    December 7, 2006 at 1:37 am
    Hi
    We have just been pulling our hairs out about this just recently…so far we have come to a temporary resolution which works but will experiment/test other compressions…i have exported vision as Quicktime
    Select Custom – Click on Format Options
    Select Compression None
    Millions of Colour
    Best
    25fps (PAL)this is Australia obviously you need 30fps
    Click OK
    Select Video Only (unless you need both Vision and Audio)
    Width Height (depends on Apect Ratio)
    Size to Fit
    Colour Levels 601/709
    Lower Field rendering and Native Dimensions (which should automatically then pop up in Width and Height anyway
    May i ask why you are not sending it out as Reference QT into AE?
  • Wes Plate
    December 7, 2006 at 6:46 am
    QT reference is a good way to ensure you don’t screw it up by setting all kinds of weird Quicktime export options.
    You should also look at Pro Import AE if you need your sequence recreated in AE with each clip on a separate AE layer. https://www.automaticduck.com/piae/
    — Wes Plate
    Automatic Duck
  • Bonnfox
    December 7, 2006 at 4:55 pm
    Thanks for your input. I’m not using a reference file, because I have to move it to another computer off the network! Thanks again!
  • Wes Plate
    December 7, 2006 at 5:12 pm
    Then you should simply export with Source Compression so that the movie uses the Avid Codec. I advise against trying to use a different codec and then possibly muck up the settings.
    — Wes Plate
    Automatic Duck
