Activity Forums Avid Media Composer AVID – add more FX to clip
  • AVID – add more FX to clip
    Posted by Terminator3 on June 8, 2006 at 7:14 pm
    i recently started to use AVID Xpress Pro and dont know how to add more FX to one clip – always when i put next FX to already FXed clip the previos one is removed by the new one !? please help, thanks a lot ! t3
    Iam mainly interested in post-productions visual FX
    Jon Zanone replied 20 years, 2 months ago 3 Members · 9 Replies
  • 9 Replies
  • Jon Zanone
    June 9, 2006 at 1:41 am
    There are two ways –
    -ALT/OPT drag the 2d FX onto the clip.
    -Step into the FX using the little arrows on the bottom left part of the timeline.
    Jon
  • Terminator3
    June 9, 2006 at 1:41 pm
    thanks for your advise, but it does not still work !? i dont know whats wrong, always when i want to add another FX the old one is replaced by the new one, even when i tap ALT or CTRL during draging FX to the clip !?
  • Jon Zanone
    June 10, 2006 at 9:12 pm
    Don’t tap it – hold the alt key as you drag…
    Jon
  • Terminator3
    June 12, 2006 at 8:40 am
    sorry, i wrote wrong expression, sure i hold it as i drag ! but it still rewrites old FX !!?
  • Michael Hancock
    June 12, 2006 at 12:20 pm
    Are you holding Alt before you select your effect? If so, don’t. Select your effect, start to drag it toward the clip you want to put it on, and hold alt before you get to it, releasing alt after it’s been dropped. For some reason (at least on my machine), if I hold Alt before I select the effect, it doesn’t register. Try it and let us know.
    Mike.
  • Terminator3
    June 19, 2006 at 2:56 pm
    thanks, it works, but new peoblem appeared, all FX i drag keep in comp monitor but not in FX control window!? =i can control only last one!?
  • Jon Zanone
    June 20, 2006 at 11:59 am
    You need to step into the effect to see the others. There are two little triangles on the bottom left part of the time line – the one on the left points down, the one on the right points up. Place your blue position line over the effect, make sure the correct track is active and click on the down arrow to step into the effect. You can keep stepping into the effect as long as there is an effect to step into. It’s a very powerful feature.
    If you are interested in visual FX, why not get into Adobe After Effects (or Apple Shake)? They are much more powerful compositing programs…
    Jon
  • Terminator3
    June 21, 2006 at 7:21 am
    thanks, ive been already using AE + premiere, wanted to try something better instead of premiere, but no essential benefits i ve found except real time trans, color cor etc… !?
    another editing thing i am not able to do in avid is to set specific
    duration of clip – fill the gap without trimming, i ve found just 50perc speed effect etc…
  • Jon Zanone
    June 21, 2006 at 11:41 am
    Replace edit is your friend. Do a search on it in the help files – I’ll try to explain it as best I can.
    In the command pallete (tool>command pallette) click on the edit tab. There is a blue arrow called ‘replace edit’. drag it to one of the buttons on your timeline or under your record monitor. If you are a keyboard guy, you can drag it to your keyboard after you open your keyboard in settings. If you want to use the add edit while playing audio, you MUST map it to the keyboard.
    Replace edit ONLY works if you have at least as much source material as your edit. In other words, if you have 5 seconds of source, and want to fill 7 seconds on your timeline, fuggetaboutit – use fit to fill instead. It’s also helpful to map an add edit button from the command pallette (search around – I don’t remember which tab it’s under) to your keyboard.
    You can add edit in any clip, or even in black. This technique is especially helpful when doing music videos. There’s an especially helpful tutorial somewhere on the COW, but I can’t seem to find it at the moment. Be careful – as you use add edit, make sure you have only the track you want to edit. If nothing else, having an audio track full of add edits doesn’t look very nice!
    If your add edit is mapped to the keyboard, play your audio. If you are musically inclined, hit add edit to the beat of the music. Don’t worry if you screw up. You can trim the add edit later. Once you are done, start adding clips as described below.
    If all you want to do is replace footage, place your blue line at the position you want to replace, place the position marker of your source and hit add edit. Remember, this only works if you have enough source footage on either side of the position line to cover your edit.
    HTH,
    Jon
