Activity Forums Adobe Premiere Pro Avid aaf project import to PPCS5.5 causes “Rendering Required files”
  • Avid aaf project import to PPCS5.5 causes “Rendering Required files”
    Posted by Andy Milne on December 12, 2011 at 2:17 am
    Hi all. If I import an Avid project using aaf and make any changes to audio levels or durations PP pauses to “Rendering Required Files”. This gets a bit frustrating as any minor changes to the audio track means a re render. However if you import the same audio track directly into PP project media thee is no rendering if you change the audio characteristics. PP creates a new render each time for aaf linked files but not for direct imported files.
    Has anyone come across this and found a solution. Is it a bug?
    Cheers
    Andy
    Andy Milne replied 14 years, 8 months ago 2 Members · 2 Replies
  • Ryan Patch
    December 12, 2011 at 4:53 am
    I’ve only seen this happen when dealing with an audio file that has a speed change (ramp) on it. Do you have a motion effect on an audio file from the AAF? That’s what’s causing it.
    Ryan
  • Andy Milne
    December 12, 2011 at 9:37 pm
    Hi Ryan. Thanks for your comments. This was an experiment I tried prior to a client bringing in their MC project and I had used an mp3 file in the project. I didn’t have any ramp on the audio so guess it was the mp3 causing the problem.
    Thanks for your help.
