Activity Forums Avid Media Composer AVID AAF error creating#
  • AVID AAF error creating#
    Posted by Jonas Bergmann on June 18, 2013 at 2:15 pm
    Hello out there,
    I am having trouble exporting an AAF from avid. As well do I have trouble exporting anything (but thats a different matter)
    I am to export my AAF as i use to, no problems there, but at the end of the export this message appers:
    Exception: Operation not supported, filename:/./././././creating/creating#
    I have absolutely no idea, what this means. Have tried searching the interwebs for answers, without much luck..
    If a kindly sould would know anything about this matter. Please.. Please! Help me :'(
    Jonas Bergmann replied 13 years, 3 months ago 2 Members · 4 Replies
  • John Pale
    June 18, 2013 at 2:48 pm
    I’ve seen this sort of thing if Avid doesn’t like the name of the file you are exporting. Does your sequence have a bunch of odd characters or a slash in it? If so, change the name. Ditto for your destination folder.
  • Jonas Bergmann
    June 19, 2013 at 11:16 am
    No, that is unfortunately not the problem. If just T’was! – nay, I haven’t yet found any solution, and I am unable to export anything at all from AVID.. Nothing is working. I may think, that the audio is the problem. We’re working with many different frame-rates and bit-depths..
    I am able to create a Video Mixdown and export it, but as comes for Audio Mixdown; not so easy..
    Therefore, my guess is, that it might be some problems in the audio. Right now I am trying, consolidating it, and open the project on another OS. If this will work.. Problem solved: Sucky lousy mac this one is!
  • John Pale
    June 19, 2013 at 12:43 pm
    My next suggestion was to consolidate or transcode the audio to a common format/bit depth.
    Glad got it working.
  • Jonas Bergmann
    June 19, 2013 at 12:55 pm
    Yeah, finally got it working – but this machine didn’t seem to be able to handle it .. But it’s almost all good. Thank you for you response! 🙂
