Activity Forums Avid Media Composer Avid 8.0.0 Install Error – Java – Mavericks (10.9.5)
  • Avid 8.0.0 Install Error – Java – Mavericks (10.9.5)
    Posted by Jon Ric on August 31, 2017 at 4:24 pm
    Hi Everyone,
    I am trying to install Avid 8.0.0 on Mavericks (10.9.5) and it is requesting that I install Java 1.6. I went to the supplied site “https://support.apple.com/kb/DL1572” and downloaded Java. Installed Java 1.6 successfully. Rebooted the computer and went to install Avid 8.0.0 again. I am unable to install 8.0.0 at this point because the following message is displayed:
    Even though my Java version is the correct version installed (1.6.0_65), I can’t get past this error.
    Any help would be greatly appreciated.
    Jon
    Chris Devine replied 8 years, 9 months ago 4 Members · 3 Replies
  • Jonathan Abrams
    September 2, 2017 at 4:34 pm
    In the Installer application, press Command+L (show log), then press Command+3 (show all entries). If you can reply here with the relevant lines from the log, or a link to the .txt file that you can save, someone can take a look at it and maybe figure out what is causing this issue.
    Alternatively, if there is a custom install option, and you do not need the background transcoder functionality, deselect it from the install options and see if that will let you install MC.
    Jonathan S. Abrams, CEA, CEV, CBNT
    Apple Certified – Technical Coordinator (v10.5) Support Professional (v10.6 through v10.10)
    Chairman, NY section, AES
  • Chuck Kahn
    September 27, 2017 at 10:31 pm
    Here’s a link to a text of the log:
    https://pastebin.com/dD2mXhhs
  • Chris Devine
    December 2, 2017 at 3:34 pm
    Was there a resolve to this issue? I’m having the exact same problem and can’t figure out how to fix.
