Avid 8 Timecode Burn-In Error
I’ve noticed incorrect numbers being displayed when scrubbing over a sequence with a default Timecode Burn-In. Occasionally a frame will display a seemingly random timecode that does not match the sequence timecode. If I just press play or fast forward, no error, (only scrubbing). If I park the play head over the frame with the incorrect display and do a mixdown or export, the correct timecode will be in the mixdown and export.
This happens in in 8.9.2 and 8.9.4.
I’m wondering if anyone else has experienced this and if Avid has released a bug fix?
