Activity Forums Avid Media Composer avid 6.5 ok for my machine?
  • avid 6.5 ok for my machine?
    Posted by Hugue Loiselle on April 28, 2013 at 2:29 am
    I have a MACbook pro
    4G ram
    snow leopard 10.6.8
    NVidia g-force 8600
    I know these are not the specs for 6.5 but if I change for Lion will it still run properly or do I have to get Avid 5.5?
    Hugue
    James Beattie replied 13 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    April 28, 2013 at 6:38 am
    I have Lion…and am running 6.5. SO it should work fine.
    Shane
    Little Frog Post
  • James Beattie
    April 29, 2013 at 11:35 am
    The biggest variable is whether you mac is 64-bit capable or not.
    After that your processor speed makes a huge difference, especially if you are using AVCIntra material or long-GOP material.
    Here is how you can tell if your machine is 64-bit capable. Surprisingly enough I have found many that are not after the upgrade.
    https://www.maclife.com/article/howtos/how_check_and_see_if_your_mac_runs_64bit
    James Beattie
    ACSR Elite/Avid ACI, Apple Certified Technician
    Consulting for Workflow and Digital Technologies at Comprehensive Technical Group
