Activity Forums Boris FX Avid 5.5.1 and BCC 7.02 authorisation issue
  • Avid 5.5.1 and BCC 7.02 authorisation issue
    Posted by Rob Clark on April 26, 2011 at 7:07 am
    I am getting an error on startup of avid 5.5.1 on a vista machine with BCC 7.02. The error comes up several times and says:
    Unable to verify authorization. Please install BCC from its original distribution CD-ROM
    I have to click this screen off several times before I can access avid. After that avid appears to work with BCC.
    I have contacted BCC support and reloaded a new install and new serial number with BCC. But same issue.
    Anyone have any ideas?
    Rob
    Rob Clark replied 15 years, 4 months ago 2 Members · 2 Replies
  • Peter Mcauley
    April 26, 2011 at 5:49 pm
    Hi Rob,
    So did you actually speak to anyone in support? If not then I’d suggest giving them a call as I’m sure they can help with this.
    You can reach them by phone at 1 888 772 6747 or via email at support@borisfx.com.
    Cheers,
    Peter.
  • Rob Clark
    April 27, 2011 at 3:16 am
    Thanks Peter.
    No only by email, but I have fixed the issue. I had two earlier versions installed BCC 4.2.2 and 6. One of them was causing a conflict. More than likely BCC 4. Removed them both and it worked.
    Thanks for your response
    Rob
