Activity Forums Avid Media Composer Avid 3D in MC3.1.1
  • Avid 3D in MC3.1.1
    Posted by Mark Adamcik on February 4, 2009 at 9:03 pm
    Howdy all.
    Has anyone re-installed Avid 3D in a MC3.1.1?
    I’m trying to open Avid 3D in MC3.1.1 BUT I get the error message:
    “There is no interactive license available to run Avid 3D”
    Avid says this (and I installed 3D OK):
    “Avid 3D file interoperability via MXF/AAF can continue to be used with the Avid Media Composer v3.0 family of
    products. However, video I/O through the hardware is no longer supported. Avid 3D must be installed directly from the
    Avid 3D folder on the install disk rather than the master installer to avoid installing the Avid v5.7 DIO which is not
    compatible with the latest software.”
    An Avid tech said update requires a MC re-install and no guarantee of results.
    I don’t like it when Avid stops supporting a product they give you.
    Mark Adamcik replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
