Activity › Forums › Avid Media Composer › avid
avid
Posted by Jason Levy on September 13, 2016 at 2:49 amHello,
Does the Media Composer run well on the new “coffee pot” Mac Pro?
thanks,
Dennis Kutchera replied 10 years ago 3 Members · 7 Replies -
Shane Ross
September 13, 2016 at 2:52 amYes. Run it on several of them in our office.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Jason Levy
September 13, 2016 at 2:57 amThanks Shane.
Could you tell me what your configuration is: How much memory, which graphics card, are you running a RAID for storage? Much obliged.
j.
Shane Ross
September 13, 2016 at 3:46 amI know we have 16GB of RAM…and the D500s. And these are connected to ISIS.
Shane
Little Frog Post
Dennis Kutchera
September 13, 2016 at 5:22 pmHey Jason,
Avid runs really well on the Trash Can Mac Pros. We’ve tried everything up to and including the 12 core with dual D700 GPUs and 32 gb of RAM. Sadly, the top configuration does not work well with DaVinci Resolve. if that is a consideration.
A lot of people find the 8 core with the D500 GPUs to be the sweet spot.Generally Avid is not too fussy with the computer you are running, but they rigourously test specific models and that is a good bet to go with because if something goes wrong, Avid can exactly duplicate your support scenario. Here is the config for the 2013 Mac Pros – https://resources.avid.com/supportfiles/config_guides/AVIDMacProIvyBridgeConfigguideRevG.pdf
I hope this helps.
Dennis
Dennis Kutchera
Online Editor / Colourist
Halifax, Canada -
Jason Levy
September 13, 2016 at 5:49 pmHey Dennis, (sorry about the typo before!!)
Thanks for that very useful information. I discovered that I should be running 4 channel RAM not 3 channel… among other things..
Again thanks,
jason
Jason Levy
September 13, 2016 at 6:23 pmAnother question… I have been running the media on a thunderbolt drive dock with a Western Digital Black 7200 rpm drive. Can you see any reason that should not work well. It’s an HD project. (Not 4k)
j
Dennis Kutchera
September 13, 2016 at 6:49 pmIt should work fine for the most part. You might have to do more rendering than if you had a raid, but I can even play a single stream of UHD off a single drive. But I am also not usually dealing with a lot of audio tracks, since I have been doing mostly online work since using the newer Mac Pros. Audio is more taxing on drive performance than video because it is lots of small files that all need to be accessed quickly. That is much harder for a drive to do than play a huge continuous video file.
Dennis
Dennis Kutchera
Halifax, Canada
