Activity › Forums › Maxon Cinema 4D › avi texture with alpha channel problem
  • avi texture with alpha channel problem
    Posted by Keiran O’brien on January 22, 2006 at 3:27 pm
    I am trying to insert live action video shot with a green screen into a C4D scene. I have used After Effects to create an AVI file with embedded alpha channel. I then create a plane object in the sceene and create a material assigned to the object and then use the AVI as the texture in the alpha channel box. However I find the resulting video is semi-transparent. Does C4D not recognised AVI texture files that have embedded alpha channels? If so is there an alternative method I could employ to insert live video of actors into a scene?
    Keiran O’brien replied 20 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    January 22, 2006 at 6:30 pm
    I’d suggest exporting to an image sequence instead- like Photoshop sequence from AfterEffects. You should have much cleaner results than AVI which depending on the codec has a not great alpha channel.
    Noah
  • Keiran O’brien
    January 23, 2006 at 5:14 pm
    Thanks for the response, I did think about the approach you suggest but I can’t see how to get the Material dialogue box to let me load an image sequence instead of an AVI. Do you know if this possible?
  • Noah Kadner
    January 23, 2006 at 5:59 pm
    Sure- you load the first frame as if it were a still, then click on the animation tab, then click calculate. The rest of the frames will be loaded.
    Noah
  • Keiran O’brien
    January 23, 2006 at 6:32 pm
    I’ve just followed the procedure you outlined but when I click calculate it reports just 1 in all the boxes. I’ve tried several variations to get it to ‘see’ all the frames in the file but without success. I’m using Ver.8.5 – would this make any difference?
  • Noah Kadner
    January 23, 2006 at 6:59 pm
    You are loading in the still from a directory in which all of the rest of the stills in the sequence are there and following the same naming scheme?
    Noah
  • Noah Kadner
    January 23, 2006 at 7:04 pm
    Just tried it. Works fine for me- but then again I’m in 9.5 so that might be an issue. Don’t forget the it will not update in the preview window, only on renders.
    Noah
  • Keiran O’brien
    January 23, 2006 at 7:05 pm
    Noah,
    yes I’ve output the original video file as a numbered sequence of TIFF images from my editing program, all into the same folder. The format is alpha characters space numbers e.g. FRED_123
