Activity Forums Adobe Premiere Pro AVI settings to be imported into Power Point presentation
  • AVI settings to be imported into Power Point presentation
    Posted by Igarti on May 7, 2005 at 9:21 am
    I’ve see questions in the other way, I mean to import PP presentations into PPro. Now wath I want is to export an edited clip inside PPro, to be used in a Power Point presentation. Which are the best settings and optimal codecs for a 5 minutes duration AVI clip?
    Ignacio
    Steven L. gotz replied 21 years, 4 months ago 3 Members · 2 Replies
  • Mike Velte
    May 7, 2005 at 11:30 am
    Mpeg 1, 640 x480, 30 fps, 2,300 kbps video, 224 kbps audio. Will play on any PC and Mac.
  • Steven L. gotz
    May 7, 2005 at 5:45 pm
    Or if you are using a PC, the quality and size difference really calls for a WM9 codec. I don’t understand everyones preoccupation with the Mac. Are there that many in the business environment connected to projectors in conference rooms? If you have to deal with a Mac, then MPEG1 makes sense. Otherwise, just limit yourself to 95% of the market and use WM9.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
