Activity › Forums › Boris FX Particle Illusion › AVI request format error??? How u fix?
Posted by Chambers on April 27, 2005 at 10:49 pmWhen I want to import an AVI file as my BG an erro comes up and says “AVI request format erro” How do I fix this problom?
thanks guysAlan Lorence replied 21 years, 5 months ago 3 Members · 2 Replies -
Aharon Rabinowitz
April 28, 2005 at 2:37 amYou are porbably using a video Codec that pIllusion doesn’t understand. Try using a different compression codec for your video – Maybe Microsoft Video? An AVI can use any number of codecs, so you need to know what it is. Also, if it’s something coming from a device, like a digital camera, and that’s the only video foprmat it can output, you can download Bink and Smacker (a free program) which allow you to convert video:
I’m not sure what people around here use. I usually use uncompressed video, and image sequence, or Cinepack Codec (for previewing, not my final video).
Anyone here have a preference for BG AVI video compression?
Aharon Rabinowitz
arabinowitz(AT)yahoo(DOT)com
http://www.allbetsareoff.com
http://www.pIllusionFusion.com -
Alan Lorence
April 28, 2005 at 12:34 pmYou’re probably trying to use a DV AVI. In order for pIllusion to load DV, you need to install a DV codec. Panasonic has a free DV codec you can install; do a websearch for “Panasonic DV codec”. You’ll find several websites that allow you to download it and give instructions on how to install.
After it’s installed, pIllusion will be able to load DV AVI files.
Alan.
wondertouch
