Activity Forums VEGAS Pro AVI rendered media into DVD Architect
  • AVI rendered media into DVD Architect
    Posted by Dror on July 8, 2006 at 10:57 pm
    This is an answer i got while back when i asked about rendering time. what i need to know is how to load sections of AVI rendered media into DVD Architect and then render it to mpeg 2.
    I use to render to mpeg2 for DVD’s, but for that paricular reason. I render to AVI now instead of Mpeg because mpeg is highly compressed and AVI is not. AVI is compressed when you render it in your authoring program as in DVD Authoring with DVD Architect 3 which I have. So I view over and over again in Vegas 6 and make your changes withot losing quality in AVI. Start thinking about rendering in sections and bring your sections into your authoring program. If you mess up on a certain section, just redo that section and your done.
    Edward Troxel replied 20 years, 1 month ago 2 Members · 1 Reply
  • Edward Troxel
    July 9, 2006 at 2:58 am
    You can render in Vegas as DV-AVI or you can render as MPEG2. However, either way you have to end up with MPEG2 for the DVD. So the question becomes: Do you render twice (DV-AVI and then MPEG2) or do you render once (straight to MPEG2)? In reality, the choice is yours.
    Edward Troxel
    JETDV Scripts
