Activity › Forums › Apple Final Cut Pro Legacy › AVI in FCP
AVI in FCP
Posted by Max Frank on June 22, 2006 at 1:48 pmcan I play an DV PAL AVI captured with Premier native in FCP 4.5?
Wayne
Max Frank replied 19 years, 11 months ago 3 Members · 6 Replies -
David Bogie
June 22, 2006 at 3:07 pmOnly if you have the AVI codec on your Macintosh. AVI had hundreds of PC-only codecs and hardly any of them were ever ported to Macintosh.
short answer: not likely but the only way you’re oging to know is to try it since there are too many variables.
bogiesan
Max Frank
June 22, 2006 at 3:52 pmThanks a lot.
One more question: If I convert that DV PAL AVI to a DV PAL .Mov, can I expect a loss of quality? And if so, is it significant?
W
David Bogie
June 22, 2006 at 10:33 pmSorry, I couldn’t tell you without knowing the parameters of the AVI file, pixel size, color space. codec, etc.
DV is a standardized format. AVI and QT are just architectures or wrappers for a huge variety of file types.
bogiesan
Sean Oneil
June 23, 2006 at 12:37 am[Wayne K.] ”
One more question: If I convert that DV PAL AVI to a DV PAL .Mov, can I expect a loss of quality? And if so, is it significant?”Yes, you will lose quality unless you use the right tool to do the conversion. Doing it in FCP, Quicktime Pro, or basically almost any program in existense will re-encode the video stream, causing quality loss.
To do it right, this is what you need:
https://www.firestore.com/solutions/catalog.asp?id=8This will do exactly what you want. It will convert an AVI-wrapped DV file into an MOV-wrapped DV file, without any re-compression.
Sean
