Activity › Forums › Boris FX Particle Illusion › Avi Import Problem
  • Avi Import Problem
    Posted by Kaiser on April 13, 2006 at 4:40 am
    I recently created a video in my camera.It’s the normal pal specs video.I imported in adobe premiere and then exported as an avi.However when i import it into PI it gives me an error saying that avi request format error.Sometimes it accepts it and then says need to change frome rate to 25fps.After it does it says error violation.The main problem is any video i try to import in Pi it says avi request format error.
    Any help is appreciated.
    Regards
    Kaiser
    Elvis Deane replied 20 years, 5 months ago 2 Members · 1 Reply
  • Elvis Deane
    April 13, 2006 at 8:49 pm
    Snipped from the pI FAQ:
    particleIllusion currently has problems with DV formats. This problem is expected to be fixed in the next update of particleIllusion (3.x). As a work around, you can use VirtualDub to convert your AVI into a codec which particleIllusion can use, or to a sequence of images (PNGs, TGAs, TIFs, etc.).
    You can also download the Panasonic DV codec, which should allow you to bring DV AVIs into pI, but beware! I’ve found that it makes some video editing programs have trouble importing AVIs encoded with certain other codecs (divx, xvid).
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
