Activity Forums Adobe After Effects AVI import issue
  • AVI import issue
    Posted by Peter Rafalow on June 19, 2007 at 8:01 pm
    I’m using hi-rez avi files in AE7 and I’m losing a ton of quality once it comes in. I’m squeezing them down for a split screen with standard video, but the avi’s are computer outputs with finely detailed lines. Comp I’m using is 720×480 for output in Avid Media Composer. Any suggestions from anyone? Many thanks.
    Steve Roberts replied 19 years, 2 months ago 2 Members · 1 Reply
  • Steve Roberts
    June 19, 2007 at 8:14 pm
    Hm. AE does not reduce quality per se. If you choose to render with a low-quality codec, then quality goes down.
    Are you viewing the comp window at full res?
    Fine lines will mess up in any app if they are smaller than one pixel wide, as you know. Try applying a 1-pixel (or less) blur in an adjustment layer over the shrunken footage. If you can’t use an adj layer, apply the blur to the footage, but increase the blur to account for the shrinkage.
    In what did you view the files before AE, when you saw them as high quality?
    What codec are the AVI files?
    What do you mean by losing quality, specifically?
    Where do you see the quality loss? The Avid? AE comp window?
