Activity Forums Adobe After Effects AVI format for stadium led displays
  • AVI format for stadium led displays
    Posted by Muhammad Qumboz on May 3, 2017 at 8:18 am
    I was asked to make banner videos that would be viewed on stadium led displays.
    The client wanted the video files in this format: “AVI uncompressed”
    I’ve rendered the video with these settings: format: AVI codec: none
    but the client said that it’s not right, and send a sample file, which I compared to the one I rendered, but it was very similar except for the following:
    1- codec: (mine)=24 bits RGB (RV24) vs (client)=15 bits RGB (RV15)
    2- bitrate: (mine)=88.5 Mb/s vs (client)=58.8 Mb/s
    the bitrate is higher in mine since I used a lot of graphics and animations
    I searched the web for these RV things and couldn’t find a solution to my problem.
    Thank you
    Muhammad Qumboz replied 9 years, 4 months ago 2 Members · 2 Replies
  • Cassius Marques
    May 3, 2017 at 5:25 pm
    Did you get the resolution right? Because I’m pretty sure unless they got a very limited output system that the bitrate would not be a problem.
    And have you tried going to 16 bit in the old .avi output options in AME? maybe its just that.
    Cassius Marques
    http://www.zapfilmes.com
  • Muhammad Qumboz
    May 6, 2017 at 11:05 am
    I don’t understand,
    in after effects I’m working under 8bpc, is that something I need to change? or do you mean other render settings? I looked but I’m still lost!
