Activity Forums Adobe Premiere Pro avi. files
  • avi. files
    Posted by Adp Hunting on November 16, 2007 at 2:40 pm
    I am using Adobe Premiere Pro 1.5
    I am working on a project that comes in alittle at a time
    I would like to edit and save sections of the project and export and save teh finished pieces as an .avi file and than when I am done bring all the finished ones back in and make the DVD.
    I was wondering if when they export out as the .avi file do the encode?
    Ryan Irwin replied 18 years, 9 months ago 3 Members · 2 Replies
  • Jon Barrie
    November 17, 2007 at 2:36 am
    Try opening a new project and then importing each sections project like it was a clip. Each imported project will come in a bin/folder. Inside there you’ll find the project files for that edit. Open the sequence for that edit. (rename it the section so you don’t have multiple ‘sequence 1’ names.) You can make a completed Project this way and export your DVD mpeg from the whole thing. Saves you HDD space by not having to render out each section then bring it together, then export to mpeg.
    – Jon 🙂
  • Ryan Irwin
    November 18, 2007 at 11:32 am
    TY.. So as long as you dont export it out into a DVD the .avi files or .mpeg files will not be encoded?
