Activity Forums Apple Final Cut Pro Legacy Avi files in FcP 7?
  • Avi files in FcP 7?
    Posted by Stevie Scarlatos on October 27, 2011 at 5:09 pm
    Hello ! I want to edit some avi files in FcP. So i will to no if possible what is the best format to convert the avi to in order to work efficiently in FCP? And what program to use to do the conversion?
    Example say if i use quick time pro to do the conversion ? Is it good to convert to dv quick time movie or else?
    Rafael Amador replied 14 years, 11 months ago 3 Members · 6 Replies
  • Cody Walters
    October 27, 2011 at 8:42 pm
    I would take your footage into Compressor and convert into ProRess 422 and match the original frame size.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Rafael Amador
    October 28, 2011 at 2:30 am
    Instead of converting try first to re-wrap them as QT files.
    Is faster and do not degrades the picture.
    Open the clips with MPGSteamclip and “Save as ..QT”.
    This will work depending on the contained codec.
    rafael
    http://www.nagavideo.com
  • Stevie Scarlatos
    October 28, 2011 at 12:06 pm
    The avi file doesn’t seem to open in Compressor neither in Mpeg streamclip.. What can in do?
  • Rafael Amador
    October 28, 2011 at 3:52 pm
    If you can’t open them in your Mac (Compressor, MPgstreamclip, FC, QT,..), then probably they content a codec not supported by QT.
    You can try to find if there is a QT component to open it.
    Perian (free) might help you too.
    rafael
  • Stevie Scarlatos
    October 29, 2011 at 12:47 am
    Thank you! Perian worked fine! I managed to play and export the files in Mpeg Streamclip, Compressor and Quick Time . I finally used mpeg streamclip to do the job. I exported the avi file to apple pro res. My only question is that i had to render the exported file in FcP 7. And i want to know if there is a way not to have to render ? Again thank you for your time..
  • Rafael Amador
    October 29, 2011 at 3:35 am
    Hi Stevie,
    Using supported codecs (as prores), FC doesn’t needs to render when the footage and sequence setting fully match. Any single difference (codec, size,..) will force rendering
    Try to conform the sequence to the footage you are editing.
    rafael
