Activity Forums VEGAS Pro avi file size
  • avi file size
    Posted by Doyal Gudgel on August 19, 2012 at 3:43 am
    My 500 gig hard drive was running a little low until I found and deleted an AVI file 167 gig big. What a relief. Is that possible in vegas? I didn’t wait around to check it out I just deleted it. I cant find where to adjust the length of the time a still picture hangs around in a slide show. I could not find it in preferences. I forgot where to do it.
    dg
    Doyal Gudgel replied 14 years ago 2 Members · 4 Replies
  • Mike Kujbida
    August 19, 2012 at 12:44 pm
    Did you render it uncompressed?
    Hard drives are very cheap these days so there’s no reason not to have a 2 TB. one on your system.
    This is in addition to your system drive as you should always have at least two drives on your computer.
    You can drag a a still out to make it as long or as short as you want.
    If you’re referring to the default time, that’s found under Options – preferences – editing – still image length.
  • Doyal Gudgel
    August 19, 2012 at 1:41 pm
    I have about half a dozen hard drives. In fact one just crashed the other day. But unless changed Vegas will put everything on C drive. A 500 gig wont last very long. I have no idea how that huge file got there.
    thanks for how to default a still length on time line. One or two manual adjustments is ok but 40 or 50 is a pain of course
  • Mike Kujbida
    August 19, 2012 at 1:48 pm
    [doyal gudgel] “But unless changed Vegas will put everything on C drive.”
    It’s always been up to the end user to decide where to put things and I NEVER put anything on my system drive.
    When I start a brand new project, I always create a master folder on drive D with several subfolders (for example: music, graphics, project files, captured video, renders, etc.).
    Even if a file exists elsewhere on my computer, I make a copy of it for the project as it makes backups a lot easier.
  • Doyal Gudgel
    August 19, 2012 at 2:12 pm
    Yes I try to put everything on another drive but over the years accdents happen. Especially the restore function. Thanks for your help
