Activity Forums VEGAS Pro avi file size mystery
  • avi file size mystery
    Posted by Andrew Jezierski on October 22, 2011 at 7:53 pm
    As I mentioned in my previous post
    https://forums.creativecow.net/readpost/24/937841
    I am re-rendering avi file (originally AVCHD rendered in Vegas 10 to uncompressed avi). The first avi is 150 GB and it took 18 hrs to render. I brought this file back to Vegas to trim it (deleted approx 1 min of footage and used one crossfade to join the cuts). I am attempting to render it back to uncompressed avi. However Vegas now is still taking 5 hrs to render and is producing a file bigger than 360 GB (I get error at that size since I have only that much free space).
    I believe I am using exactly the same setting for rendering so why the size doubled?
    Andrew
    Andrew Jezierski replied 14 years, 10 months ago 2 Members · 2 Replies
  • Stephen Mann
    October 23, 2011 at 2:44 am
    [Andrew Jezierski] “I believe I am using exactly the same setting for rendering”
    Probably not. File size is determined almost entirely by the encoding bit-rate.
    Why uncompressed AVI?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Andrew Jezierski
    October 23, 2011 at 7:47 am
    I am using uncompressed avi for VDub to resize to SD and compress for DVDA. I just cannot think about any setting that would’ve changed apart that with the second rendering I went from Best to Good with the goal to lower the size of the file.
    Andrew
