Activity Forums Avid Media Composer AVI file size
  • AVI file size
    Posted by Ingo Helbig on June 25, 2008 at 11:01 am
    I am trying to export a clip out of avid as an AVI but the file size seems to have a limit of 2gig. I can’t find a setting that lets me make a bigger file than this. Can someone tell me if this is as good as it gets, or is there a work around.
    Chris Paul replied 18 years ago 4 Members · 4 Replies
  • Michael Hancock
    June 25, 2008 at 12:14 pm
    There is a 2GB limit on AVI exports from Avid. Why? Not sure. Last I heard it’s because of the type of AVI Avid can export, which was originally subject to a 2GB limit for some reason.
    The best way to get around this is to export a Quicktime and take it to a computer with Sorenson or ProCoder or another compression/conversion program and convert the quicktime to an AVI there. If you have one of these programs installed on your Avid just export a Quicktime Reference, then convert it.
    Michael.
  • Ingo Helbig
    June 25, 2008 at 4:07 pm
    Thanks Micheal. appreciate the help
  • Jon Zanone
    June 26, 2008 at 1:07 am
    For general info – the 2gb limit is an OS, not an Avid limitation…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Chris Paul
    September 15, 2008 at 1:18 pm
    I’m also trying to export a chunk of AVI files from Media Composer 2.8. I have Squeeze but don’t see any AVI options. Any ideas?
    Chris
