Activity › Forums › Apple Final Cut Pro Legacy › AVI file format
AVI file format
Posted by Larry Watts on November 6, 2009 at 10:18 pmCan the latest version of Final Cut Studio recognize and utilize an AVI file produced rendered on a PC?
thanks
Larry
Larry Watts replied 16 years, 10 months ago 3 Members · 3 Replies -
Michael Gissing
November 6, 2009 at 10:44 pmAVI is not a codec, just a wrapper. FCP works best when it has a quicktime wrapper so firstly the AVI needs to be converted to a quicktime and also you may need to transcode the codec to something that editis nicely in FCP.
I have in the past dropped an AVI animation codec file into an FCP timeline (final animated graphics file) and just let FCP render it as I was onlining and adding a late change before playing out to tape.
If you are editing then it would be smarter to convert to a quicktime to avoid endless rendering everytime you change an AVI clip
Jeff Gerst
November 6, 2009 at 10:52 pmI work with avi files all the time – you can import them without a problem. I have found that they exhibit weird behavior sometimes, like getting out of sync, so I usually render them to a mov first, then import.
