AVI file
Posted by Gerry Condez on June 11, 2013 at 9:26 pmHow to get .avi files to media 100? Is there a converter that I can use? Thanks
Check out the camera support I designed at
https://camerasupportbracket.comGroot James replied 13 years, 3 months ago 4 Members · 4 Replies -
Jaeson Koszarsky
June 13, 2013 at 8:27 pmWill Media100 import the AVI if you change the IMPORT TYPE file filter to ALL?
You could try FLV crunch if you want to convert files outside of M100.
https://download.cnet.com/Flv-Crunch/3000-2194_4-10909295.htmlWe use Sorenson Squeeze but it’s a little more expensive.
Jaeson
Gary Milligan
June 14, 2013 at 6:09 pmMPEG Streamclip (free) will convert – at least it worked for me when I did a quick test a few minutes ago.
HTH
Gary
Gerry Condez
June 14, 2013 at 10:45 pmThanks you guys. If you dont do that file often, you forget. I appreciate the help.
https://camerasupportbracket.com -
Groot James
June 17, 2013 at 3:11 amSimply convert the file to a more common format like mp4.
I used AppGeeker for a while, it wasn’t that bad, never had any problems with it.
https://www.appgeeker.com/how-to/convert-avi-to-mp4-mac.html” Everything in this world has a loophole…..you just need to find the right one ! “
