Activity Forums Apple Final Cut Pro Legacy AVI export is giving me unrendered portions of video
  • AVI export is giving me unrendered portions of video
    Posted by Jason Noto on May 11, 2006 at 10:15 pm
    hi,
    I am trying to do a quicktime conversion to an AVI. My final cut file is completely rendered, both audio and video, and plays fine when i watch it in final cut. But, when I export it with the AVI quicktime conversion, many of the transistions and cuts are showing up as unrendered when i watch it. “unrendered” flashes up on the screen where the cuts or transisitons should be.
    Does anyone know what could be causing this, or how I could export a rendered/ completed version of my file to an AVI
    Thanks. I appreciate any insight and info you are able to share
    Jason
    David Gerberding replied 20 years, 1 month ago 3 Members · 2 Replies
  • David Bogie
    May 12, 2006 at 2:22 pm
    Export a self-contained version of your project. Reimport it. Use the self-contained move as the source for your AVI.
    bogiesan
  • David Gerberding
    August 8, 2006 at 10:16 pm
    The other way to fix the issue if you have very few real-time effects on your timeline, is to make sure the “Full” or dark green line is checked in your “Sequence/Render Selection” or “Sequence Render All” drop down menu. Then go ahead and render the few effects. This will turn the line above the effects blue and you’ll be able to get a clean AVI file.
