Activity Forums Apple Final Cut Pro Legacy AVI export bug in FCP?
  • AVI export bug in FCP?
    Posted by Mike Salerno on June 20, 2007 at 4:15 pm
    Hello All,
    I need to export uncompressed AVI’s out of final cut pro 5.1.4. I am working in 1080i uncompressed HD.
    After my export is complete and I go to playback the file, it appears that only 12 seconds of my 3 minute clip has exported, however, when I check the file size, it appears to contain the size of a 3 minute clip at 21 gigs.
    I have also had problems with .WMV files where the full file does not export. Is this a bug in FCP or has any dealt with a similar situation? Any advice would be appreciated. Thanks in advance.
    David Bogie replied 19 years, 3 months ago 5 Members · 4 Replies
  • Dream Master
    June 20, 2007 at 4:30 pm
    I always export as a quicktime, and then I use Streamclip 1.8 to convert to whatever format I need it to be in…. a google search on mpeg streamclip will get you to the program…
  • Russell Lasson
    June 20, 2007 at 4:33 pm
    [Salerno] “I have also had problems with .WMV files where the full file does not export. Is this a bug in FCP or has any dealt with a similar situation?”
    WMV support is provided by Flip4Mac, not FCP. In order to export full WMV clips, you need to purchase the extended plug-in.
    That might be what’s causing the AVI problem too.
    -Russ
  • Alan Lacey
    June 20, 2007 at 5:36 pm
    There are some file size limitations with avis. Do a search to research this.
    Also remember the FAT32 limit if you’re wanting to get these to a PC.
    Alan
  • David Bogie
    June 21, 2007 at 4:48 pm
    If you must do this regularly and expect to enjoy doing it and to get paid for it, buy a PC. Export your sequences as self-contained movies in a format your PC will recognize, transcode them over your network on the PC to AVI.
    AVI is s-o-o-o 80s. You need to determine why your clients need AVI. They probably don’t, they just don’t know any better.
    bogiesan
