AVI compared to MPEG
Posted by Pieper1 on January 25, 2006 at 7:51 pmi am making a video that has some text at the beginning and then it goes into the video. im rendering my project to NTSC 720×480.
will mpeg give me a better picture than avi? file size and the time it takes to render is not an issue.
if there is any other format that would look better i would like to know or if there are any settings that i can change in avi or mpeg to make the quality better that would be helpful too.
Edward Troxel replied 20 years, 8 months ago 6 Members · 12 Replies -
Edward Troxel
January 25, 2006 at 8:13 pmDV-AVI is bigger than MPEG. If you want small, go with MPEG2
DV-AVI is better than MPEG. MPEG is compressed more highly than DV-AVI.
However, you need to use the format for your intended destination. For example, if you’re creating a DVD, you MUST go to MPEG2. If you’re printing to tape, stick with DV-AVI.
Gary Kleiner
January 25, 2006 at 8:15 pmGenerally speaking, AVI is less compressed than Mpeg, therefore will look better. The most important question is: what is your destination format? Are you going to tape? DVD? Web?
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Pieper1
January 25, 2006 at 8:23 pmi am going to dvd
would making dvds with avi cause compatibility issues possibly? because recently i did an project and i got a lot of dvd’s back because they would skip in the middle or just plain wouldn’t play. i used DVDA3 and the data rate was 8.0
Stephen Mann
January 25, 2006 at 8:36 pmA DVD player won’t know what to do with an AVI file. It must be MPEG2.
For my work 8Mb/sec is too high a data rate. I burn everything VBR with an average of 4MB/s and a max of 5Mb/sec or less. The difference from 8Mb to 5Mb in image quality with my work (stage productions) is so small that I can only see it if I know where to look – and I’m not telling my clients where to look. Coming up on the four year mark in business and not one client has returned an unplayable DVD yet. (Except for the grandma who couldn’t get the disc to play on her CD player.)
Steve Mann
Carlo Simone
January 25, 2006 at 9:19 pmAnother way of accomplishing this task is to simply render out to avi, import to DVDA and let the software do the re-compress for you. This is generally a longer process because you are rendering out to two seperate formats. If you render out your video to MPEG2 properly in Vegas, DVDA’s DVD prepare time is much shorter.
Hope this helps..
Pieper1
January 25, 2006 at 9:36 pmthank you for your quick and helpful responses
one last question though…what is the proper way to render mpeg2 to DVDA…there is a mpeg template that is called “DVD Architect…” but it doesnt render audio
i guess i just need to know what format and the settings should be on that format and that would help me tons
thanks
Edward Troxel
January 25, 2006 at 9:40 pm -
Gary Kleiner
January 25, 2006 at 9:49 pmFunny about the CD player 🙂
I would think that stage productions would be one of the more noticable types of videos that would show the differences in compression rates because of lighing contrast and large areas of one color (curtain, etc).
If 5Mbps works for you, that’s great, but would caution others reading this that anything below the 6 – 6.5 range might be an unacceptable compromise unless it’s really evenly lit with very little action taking place.
Bottom line is that you want to get it as close to 8Mbps as you can and still fit it on the disc. In certain cases, I split shows into two discs to allow for less compression.
Gary Kleiner
Stephen Mann
January 26, 2006 at 4:36 amI did a blind test (admittedly with a limited audience) and the viewers couldn’t see any difference in 5 or 8 Mb/s.
You are correct that others should do their own test, but I was willing to compromise a little quality for playability.
Charley King
January 26, 2006 at 5:47 pmAlong this line, I create my DVD’s with VBR 8M maximum, 6M average, and have never had a complaint about playability.
Personally I have always felt, show the average Joe Blow a VHS playback and a Beta playback and he would not really be able to tell the difference, but I am not going to start using VHS for my acquisition or normal playback options.Charlie
ProductionKing Video Services
Unmarked Door Productions
Flamingo Las Vegas Hotel
Las Vegas, Nevada
