Activity Forums Blackmagic Design AVI codecs still unusable…for rendering in after effect
  • AVI codecs still unusable…for rendering in after effect
    Posted by Oscar G. on September 13, 2005 at 2:38 pm
    Hy
    after installing black magic avi codec on a stand alone computer we can now perfectly read decklink captured videos but we can’t render to blackmagic 4:2:2 codec…
    So we have to use uncompressed rgb, wich file are a bit larger…
    any solutions?
    Regards
    Sameer Shrivastava replied 21 years ago 4 Members · 9 Replies
  • 9 Replies
  • Luke Maslen
    September 14, 2005 at 1:46 am
    Hi Oscar,
    I’ll see if someone can test this today or tomorrow and get back to you. From which application(s) are you trying to render to the Blackmagic 4:2:2 codec?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Oscar G.
    September 14, 2005 at 9:52 am
    Hy luke
    thanks for reply
    Directly from after effects 6.5, i render a composition in avi black magic 10bits 4:2:2, pal 720X576.
    When i render i have this message:” after effects error: an unspecified avi or directshow error occured. insuffisant space disk to run task. (8) (53::25)”
    the part of the message in italic may be some different because i translate it from french.
    if i use an other video utility, virtualdub for example i have an error to..
    i tried the stand alone codecs on two computers (both were independant workstations in dual xeon configuration)
    i tried to use 8bits hd codec to render in pal, but it is the same issue…
    the codecs are the 4.9 version
    those problems don’t occurs on computers which have the decklink extreme
  • Luke Maslen
    September 14, 2005 at 11:19 pm
    Hi Oscar,
    Thank you for your additional information. We will try to replicate that and then reply to you either way with what we’ve found.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Andrew Mcleod
    September 15, 2005 at 12:11 am
    Hi
    Sounds like you are out of Disk space or have a disk error – can you check your disks and video array via Disk Management and perform a surface scan and verifiy how much space you have left.
    Andrew McLeod
    Blackmagic Design
  • Oscar G.
    September 15, 2005 at 10:15 am
    Hy andrew
    No it isn’t a problem of disk space.
    Ours disks on all computers tested have more than 10 Gb of freespace in local drive.
    For the network drive we have more than 70GB free (computers on where we render with the decklink)
    By experience, sometimes if the codec has “a problem” it return an error like that (for ex you use a wrong definiton of video for the codec), because the case avoid writing data on your hard drive: the computer thinks your stuff is wrong.
    I said sometimes.
    we will wait for the reply of the blackmagic team , who are experts on programmation/errors on their products, because many factors can produce an errors on a computer…
    regards
    Oscar
  • Andrew Mcleod
    September 16, 2005 at 7:07 am
    Hi Oscar
    Can we modify your workflow so that you render to a local disk array then move it to the network drive ?
    This may help the process.
    Andrew McLeod
    Blackmagic Design
  • Oscar G.
    September 16, 2005 at 9:18 am
    Hy Andrew
    All tests i’ve done were on the local hard drive..
    But i retry it, and it was the same problem.
    Do you think some other codecs could developpe an imcompatibility (xvid, divx, indeo, matrox digisuite codec suite -mjpeg,dv25,dv50,dvcpro,mpeg2- )?
    All ours computers with a decklink and those codecs can render correctly with the blackmagic avi codec.
    Regards.
    Oscar
  • Sameer Shrivastava
    September 24, 2005 at 8:39 pm
    Is it possible to render with black magic codec without the blackmagic card ? i know one can read the files but suppose it needs the hardware to write one.
    sameer
    sameer
