Activity › Forums › Boris FX Particle Illusion › AVI as a background
AVI as a background
Posted by Geoff Hodgson on June 15, 2006 at 4:17 pmWhen I use an avi as a background all I can see is a black scene. No thumnail appears in the grey window. Is there something obviouis I have done wrong? Any help appreciated.
Geoff
Geoff Hodgson replied 20 years, 2 months ago 3 Members · 4 Replies -
Elvis Deane
June 15, 2006 at 5:13 pmWhat program are you exporting the AVI from? There are some specific settings I’d have to select in Vegas before exporting to pI, otherwise I’d get the same thing.
This is what you need to do specifically for Vegas, but maybe these settings will give you some clues.
In the Video tab, make sure the Video Format is set to Uncompressed. At the bottom, there should be two checkboxes, Render Alpha Channel, and Create an OpenDML (AVI version 2.0) compatible file. Make sure both of these are checked. If you render with them unchecked, the AVI loads up as a blank in pI.—
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Geoff Hodgson
June 15, 2006 at 5:48 pmElvis,
Thanks for very quick response. I was exporting from Flash and have now set the export parameters as ’32 bit colour/w/alpha’ unchecked ‘compress video’ and left checked ‘smooth’ It now imports into PI. Thank you very much indeed for your help.
Geoff
Dennis Fassbaender
June 19, 2006 at 2:04 pmYou can use DV-compressed files, too. This is very great, because i ever thought DV-AVIs from my Camcorder can
