Activity Forums Apple Final Cut Pro Legacy AVI and EWC files
  • AVI and EWC files
    Posted by Hector Mata on June 4, 2011 at 2:39 am
    Hello all,
    I am trying to use some footage and edit it in FCP. The files I am trying to use comes in packages of two items. One file that ends in .avi and another one (that uses the same name) with .ewc
    Have tried AVCWare MAc Video Converter, MPEG Streamclip with no luck. PLs help!!!!!
    I am using FCP6 and MAC OSX 10.6.5
    Best,
    Hector
    Hector Mata replied 15 years, 1 month ago 3 Members · 5 Replies
  • David Roth weiss
    June 4, 2011 at 3:49 am
    I think you meant .ecw, not .ewc. Right?
    If so, an .ecw file is an enhanced compression wavelet file for satellite imagery. It requires special players. If you Google it you’ll probably find what’s out there.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Hector Mata
    June 4, 2011 at 12:24 pm
    David,
    Thanks man. You are right, the files were generated by a company that send video reporting to the wires for broadcast purposes.
    Do I have to convert the ecw files as well as the avi files?
    My understanding is that the avi file is a self contained video file with sound right? If that is the case I just need to convert the avi file into something that FCP reads. Any recommendation on converters? Have tried few with no luck.
    Thank you very very much for your help
    Best,
    Hector
  • David Roth weiss
    June 5, 2011 at 6:13 pm
    Not sure Hector, that’s why I suggested that you Google for the answer.
    David Roth Weiss
    Los Angeles
  • Kevin Reiner
    August 15, 2011 at 4:32 pm
    Hello Hector (and David)
    I have been given some .avi and .ewc2 files to use in a FCP project. As David suggests, I googled to find a way to convert the files for FCP. Unfortunately, the only useful link I can find happens to be this thread. 🙂
    Did you happen to figure it out Hector? I’ve tried VLC, MPEG Streamclip, Wondershare Video Converter. Perian. Nothing seems to work.
    Kevin
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Hector Mata
    August 15, 2011 at 5:53 pm
    I have just recently purchased Aunsoft Final Mate for a different job that involved AVCHD footage and the software offered conversion for a large variety of AVI files. Have not tried it for AVIs yet but the conversion from AVCHD into PRORES was perfect.
