Activity Forums Compression Techniques average size for 5 minute video
  • average size for 5 minute video
    Posted by Arty Gold on August 25, 2006 at 2:48 pm
    i know it’s hard to say…
    but let’s say i have a video in final cut pro…nothing to dramatic…a 5 minute marketing video
    i want to compress it down for the web…
    320×240
    i bring it out then squeeze it in squeeze…
    what would you say the file size should be ?
    and is there another way i should do it ?
    i tried bringing it out in compressor it didn’t seem to be giving me good quality
    i’m on a mac g-5 duak 2.7
    Arty Gold replied 19 years, 8 months ago 2 Members · 4 Replies
  • Ed Dooley
    August 25, 2006 at 6:19 pm
    The file size can be whatever you want it to be. If you compress it to play back for the slowest DSL (384kb),
    you’ll get one size. If you compress it to play back for 512kb or 1.5mb, you’ll get 2 other sizes. It’s simple math,
    the data rate you choose (a kb is .125 of a KB, which 1,000 of those KBs add up to a MB, close at least), so data rate times length
    of video= file size
    kbs=kilobit per second
    KBS=kilobyte per second
    MB=megabyte per second
    Instead of remembering 5th grade math, though, you can use the handy AJA Data Rate Converter (OSX):
    https://www.aja.com/html/support_kona3_swd.html
    Scroll down to: AJA Data Rate Calculator Application (Version 2)
    This OS X software application calculates data rates and storage requirements for a given video size, format, and frame rate. It’s great for both KONA and Io users as a resource for configuring systems and determining storage requirements.
    Ed
  • Arty Gold
    August 26, 2006 at 11:36 am
    this data calculator only shows video sizes
    what about 320×240
    i understand the math part of it…
    but i’ve been exporting the video out of fcp thru the quicktime conversion
    i get an ok quailty video but it doesn’t seem like a small enough file
    so then i put it thru squeeze but it’s not really working so well
  • Ed Dooley
    August 27, 2006 at 11:19 pm
    I linked to the wrong calculator. FFMPEGX has a calculator for all kinds of sizes, rates, etc.
    https://ffmpegx.com/download.html
    I gave you the math because you didn’t say (and you still haven’t said) what target bit-rate you want.
    Choosing your intended audience’s connection speed is one the most important things in determining
    your bit-rate, which in turn determines your video’s final file size. You asked: [Arty] “i bring it out then squeeze it in squeeze…
    what would you say the file size should be ?”
    And I answered what the file size should be is based on what connection speed your audience has (hence the math). Squeeze should be
    making good looking videos at 320×240 at even the lowest 300kbs rate (and if you do the math you’ll see what the
    file size should be- or use the new FFMPEGX link I sent you). If you want more help, you’ve got to give more information.
    Ed
  • Arty Gold
    August 30, 2006 at 2:53 pm
    thanks my man
