Nigel O’neill
April 1, 2011 at 3:39 amI use brand new Panasonic DV tapes only once for a paid job and I NEVER mix brands as some tapes use a ‘dry’ formulation and others use a ‘wet’ formulation. I believe Sony uses ‘wet’. The drum mechanism in tape based cams can get affected if you constantly switch between tape formulations, so it’s good to stick to one brand, which I do.
John, I didn’t realise the drop out/duration was that long between DV and HDV tapes. Learned something new today 🙂
I have experienced drop-outs in AVCHD where one file ends and another begins, especially during long recordings. Another user on this forum suggested using an MS-DOS binary copy to combine the files, which I have yet to try out.
Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
John Rofrano
April 1, 2011 at 4:15 am[Nigel O'Neill] “I have experienced drop-outs in AVCHD where one file ends and another begins, especially during long recordings. Another user on this forum suggested using an MS-DOS binary copy to combine the files, which I have yet to try out.”
That’s not a real drop-out. That’s something the camera always does when it hits the FAT32 file size limit. Doing a binary MSDOS copy usually fixes it.
~jr
http://www.johnrofrano.com
http://www.vasst.com
