Activity Forums Apple Final Cut Pro Legacy AVCHD to ProRes
  • AVCHD to ProRes
    Posted by Peter Lawrence on November 25, 2009 at 1:15 am
    My first post here although I’ve already learned a lot by reading some of the existing threads.
    Hopefully someone here can help me with this question. If I ingest AVCHD footage into one of the ProRes formats does the conversion process do colour smoothing/interpolation? To put the question in context, I am looking at doing some Chroma keying and am wondering whether I should be preceding the keyer with 4:2:0 or 4:2:2 colour smoothing.
    Any insights would be greatly appreciated.
    Kelly Scott replied 13 years, 11 months ago 3 Members · 4 Replies
  • Ben Holmes
    November 26, 2009 at 12:41 pm
    As your footage was originated 4:2:0, it will always carry this limitation in chroma info, so the smoothing will probably help.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Peter Lawrence
    November 26, 2009 at 12:52 pm
    Yeah, I was just wondering whether the ingest to ProRes process actually did the smoothing to 4:2:2.
  • Peter Lawrence
    November 26, 2009 at 2:00 pm
    I suspect the answer is that it does do the smoothing. I just found this in the Apple ProRes White Paper
    “All Apple ProRes 422 formats can support 4:2:0 or 4:1:1 sources by upsampling the chroma to 4:2:2 prior to encoding.”
  • Kelly Scott
    October 25, 2012 at 8:35 am
