Activity Forums Adobe Encore DVD AVCHD to DVD transcode settings
  • AVCHD to DVD transcode settings
    Posted by Jamie Burkhardt on October 4, 2013 at 3:02 pm
    Hey all,
    Sorry if this has been asked before, I’m trying to take AVCHD files of a football game I shot and put them to a DVD. I’m using Adobe Encore CS 5.1 and I know I can use the automatic transcode settings to bring the HD footage down to 720 for DVDs. However I was just wondering what’s the best way, if any, to get the best quality. Should I just use the automatic settings? Transcode the files to MPEG-2 DVD in PPro? Maybe a third party application?
    Any input is appreciated, as I was told it’s better to shoot in HD and make DVDs from that instead of shooting in regular SD and making DVDs.
    Jamie
    Daniel Ludwig replied 12 years, 11 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    October 7, 2013 at 5:31 am
    jamie,
    in general it´s better to shoot in HD then SD, but to answer your questions accoring to bitrate for DVD – it´s a little bit difficult to tell you any setting, as it is depending on the duration of your film and the numbers of your audio-streams.
    SD is 720×480 (NTSC), or 720×576 (PAL)
    you can use any DVD-complient encoder to create MPEG2 for DVD. what´s your budget?!
    try using different ones on some test-clips and find out what would be best for you.
    I would say – try CCE (cinecraft encoder)…. if you would like to have briliant results.
    cheers
    danny
